- 4:33 PM
- Dec 30, 2015
- Centre County
Old logging camp trick: wraps few turns of worn thin rawhide boot lace around bearing to keep grit out.
.058 husky x-cut. It grinds and files nicely. My only gripe about this chain is that I feel like I waste 25% of the tooth converting it due to the amount of hook. I’ll pull my arm off and check out that bearing, thanks guys.Is that Archer chain?
How does it hold an edge? There's a local shop that sells reels of Archer chain for a decent price.
My Archer chain stretched considerably when new. Then it settles on. Just be aware.
Great profile!! That’s gonna cut!After disassembling, greasing, and reinstalling my arm, no more slop! I have been loving this 451.View attachment 253840
That’s going to be a play chain, I don’t think it will hold an edge for chit.Great profile!! That’s gonna cut!
I still debate the slight beak being faster. I know some do it intentionally on race chains, I prefer the perfect corner. That chain is going to be in a group of chains I test, I have 6 different chains, all quite a bit different to run.It looks like it is just slightly side-beaked, which is fine for playing around. It won't hold an edge as long like you say, but will initially be a hair faster in the wood.
When I was commercial thinning, I would run a slight side beak because I was decreasing the back-slope of the top plate and running the rakers just a hair shallower,
which made for a very fast cutting chain in young softwoods.
According to everything I have read, that is of no concern.![]()
I moved the chain guide more forward in my simington 450. Now the straight line from the working corner doesn’t line up with the inside corner. I am thinking because I have a more acute or flatter grind angle on the top plate, it won’t intersect the inner corner.
My question is, is this an issue? does it seem too aggressive? I haven’t got a chance to cut with it yet.
