Show off your muffler mods
7:51 AM
Do you think it might be the plating that’s making things difficult and not the metal itself? Maybe could try blasting it, glass bead or aluminum oxide, etc.
It’s more of a discoloration than a plating. Silver solder flux turns it bright silver instantly. Any grit sandpaper will shine it up also. And then heat turns it back yellow
7:51 AM
It helps to sand it off first. Filler won’t flow at all if coating isn’t removed.
ErnieG
7:51 AM
Northeast PA
This is my 395 I picked up that took a hit and broke a piece of the case and dented the muffler so it was a good place for a deflector and I smooth ground the jagged edge on the case .
I have to find some touch up paint for it and possibly gonna weld the deflector on the muffler on the future.
Ernie
MemphisMechanic
Unreliable Chainsaw Enthusiast
6:51 AM
Memphis, TN
Ernie
Way to make a software bug into a feature. Looks like it was modified on purpose. 😎
Catfishclark89
6:51 AM
Glasgow, KY, USA
Alright finally figured out a deflector to keep the exhaust off clutch cover on my 400. Took some stainless sheet and cut out a little pattern and bent me the shape I wanted. Then tigged it up. Now these welds weren’t pretty. I’m not accustomed to welding stainless this thin. But I turned the amps down to 30 and ran a sharp tungsten. Polished the stain off the muffler and started tacking. Holding more to the muffler and running filler to the deflector and following back to the muffler. Really had to keep moving and still had a couple problems but at least it turned out so here she is ugly welds and all. (The first two pictures are to show the opened up factory outlet and how I ground out the factory deflector.)
Member
6:51 AM
Woodslasher
Teh debil
4:51 AM
Commiefornia
Just be sure to match/bevel the entry from the exhaust port so it's not hitting a square edge sticking into the port and your gasket too.
That will be done when I get the 056 Mag II jug securely mated to the 066 case and I get the mounting adapter between this miffler and that jug figured out.
srcarr52
7:51 AM
Iowa City
