Woodslasher
Teh debil
- 1:17 PM
- Mar 18, 2021
- Commiefornia
Why didn't you cut the tab and fins off the back outlet?
Ya I always cut them off. Nice job anyway Mason!Why didn't you cut the tab and fins off the back outlet?
Three reasons: 1: it’s loud enough for me. 2: it routes the exhaust to blow over the top of the 2nd deflector so it doesn’t hit the 2nd deflector and burn the top cover. Which already has a reputation for melting on this model. 3: no need to add any more outlet area. It’s at 100-125% exhaust port width with the two outlets. However…. on my 395 that’s a single gutted port, yes I removed those tabs.Why didn't you cut the tab and fins off the back outlet?
Why not add an exit on the flywheel side to rid the operator of fumes & heat, as well as allow a much more efficient instrument or tool for the task at hand ???Three reasons: 1: it’s loud enough for me. 2: it routes the exhaust to blow over the top of the 2nd deflector so it doesn’t hit the 2nd deflector and burn the top cover. Which already has a reputation for melting on this model. 3: no need to add any more outlet area. It’s at 100-125% exhaust port width with the two outlets. However…. on my 395 that’s a single gutted port, yes I removed those tabs.
Nah. I prefer pto side outlets if possible. Nothing wrong with doing it your way either Kev. Just personal preference. Use what works best for you.Why not add an exit on the flywheel side to rid the operator of fumes & heat, as well as allow a much more efficient instrument or tool for the task at hand ???![]()
I get it, you don't do much flush cuts or milling.Just personal preference. Use what works best for you.
Most muffler modifications require trimming of something, in this case, a little nip/tuck here/there doesn't hurt anything.Don't you have to cut plastic when you mod your way Kevin? I wonder why the Hooskie engineers didn't put the factory deflector on the other side?
I milled with a 395xp and it was a better experience with a cigarette hanging out of my mouth.I get it, you don't do much flush cuts or milling.
The 394/5 mufflers tend to "bounce" exhaust back into the saw & operator when modded your way, especially on the larger diameter cuts. those same muffler mods stumping really lets the guy know what kind of dirt the tree grew up in, and milling lets the operator know what fuel and oil they use
I ran a 395 with a stock muffler while milling, that mfer was nasty at best and it nearly made me pass out at one point. The exhaust just wouldn't leave, it would hover around and choke me out unless I had my head positioned just right so I could benefit from the air movement near the flywheel. Fast forward to when I put my 2100 on the mill and all the nasty exhaust issues were gone. As I recall, on the 2100 the exhaust points sorta down towards the bottom of the saw so even when you're bucking/felling a big one the exhaust is getting blown away from where you're cutting.
