Saw video thread
7:41 AM
And I'll correct myself -- it's the "Maxflow" filter to try. No cover... just bolt on the foam and give her a go.
I'll give this a shot w/ my hybrid next time I have it out.
Maybe I'll hit the sugarbush over the break and do some testing.
I think removing the cover helps to keep filter cleaner longer but ya can’t use it in the rain or snowing conditions :(. I think the max flo would be nice with the cover it comes with, best all around setup for a worksaw perhaps?
7:41 AM
I have no idea Kevin. I run them. I don't build them.
Simma down now big guy..
It's all good...
AND leave my mother out of it...
7:41 AM
It's all good...
Just seemed like a cheap shot to me.
I spend 10-12 hours on a saw trying to make something that’s powerful, clean-looking, and will stand the test of time and it’s insinuated that the power all comes from a healthy timing advance
TreeLife
I'm Dominick
7:41 AM
I dont think that's what jeff was insinuating at all, Kevin. We all know you do excellent work and are turning out good product.
7:41 AM
You find any gains retarding timing yet? [emoji6]
malk315
Running Saws for Therapy
7:41 AM
Lancaster, MA
Eric’s hybrid is quite the hybrid. Doc ported it. I ran it a while back. 25” 8 pin.
She's not even broken in yet. Gotta get a few more tanks through.
We used it at a land clearing job in November and really enjoyed dropping and bucking a few nice oaks with her... Pulls with authority. In that case was running Stihl lightweight bar 28" with 7 pin and LGX oregon chain. I tried to use RS but I am much happier with a freshly filed LGX loop and I'll be sticking w/ that :)
7:41 AM
Every now and then it’s there. The real high rpm saws advance fights itself. One had a head and much more efficient chamber too. That might have helped a lot
I’ve heard it mentioned before. I could definitely see it fighting itself on a really high rpm saw. Most of the stuff I do is geared between spicy and torquey. I don’t venture into the race market much
7:41 AM
On the subject of timing advance, a saw popping in the cut with too much advance is like nails on a chalkboard to me. Makes me cringe :confused:. I’ve had to dial back the timing advance some other people did to saws I’ve had go thru here to fix. I don’t say anything, you just learn what not to do lol. I was conservative with the 440 (about .018 off the key) because I didn’t want it kicking the pull cord. Which is annoying on a worksaw, wears on you and the starter after a while.
7:41 AM
Some kick the pull cord, some don’t. Some quit popping under load or with a leaner tune. Some will pop even leaned out to where there is a bog from idle. It’s a fine line between getting some added performance and going a bit too far.
7:41 AM
I’m cool with sacrificing a little on the table in trade for use ability on a worksaw
Wonkydonkey
Plastic member
12:41 PM
Sussex, UK.
I'm gonna poast, my err44 build testing cuts vids here. the thing with this saw i found is the adv on the key way 20 or 30 thou, you can decide ;)
Yes it’s an 18” duromatic bar with an Oregon 3/8 that has the rakers set a tad below the soft wood setting. Umm I’m Cutting hard wood :risas3:.
And yes nails were found :( in the first vid.
After a sharpen and a change in key (30thou) no change in rakers, same wood.. just up a bit higher. I was holding on tight :D,, and no more nails
