Saw video thread
9:15 AM
440 I ported on the first tank of gas tuned conservatively. 25” 8 pin full comp. I was pushing pretty good first couple cuts to test the powerband width, quite a forgiving saw. We’ll see how it holds up. 138DA12A-A52E-47EB-AB14-89F5BE131A2C.jpeg Wood was frozen hemlock. Which cuts like a rock this time of year.
jk14
9:15 AM
Glenside Pa.
Nice.
Just me, but I prefer. 325 on 50cc saws. Keeps the saw in its operating sweet spot a little better. Thus making for faster cuts.
I hear you there, but this saw is going out for an attitude adjustment. I'm positive it will run this setup with authority when it comes back.
9:15 AM
The 440 and 572 were about even before the 440 was modified. The biggest gain was in torque. It was pretty easy to stuff the 440 stock. Not anymore, now you have to be trying to stuff it.
malk315
Running Saws for Therapy
9:15 AM
Lancaster, MA
Do you have a fastflow to try on that 440? Would love to see a couple of timed cuts w/ HD-2 and fastflow ... hopefully w/o any re-tune required but if absolutely necessary do the re-tune. Start with HD-2 set optimal, then change out for fastflow and if you are comfortable w/ making a cut w/o touching the tune go for it. If it needs a little more fuel ... no prob.
Cheers Mason!
9:15 AM
Cheers Mason!
That thought crossed my mind, I think it would benefit. It already has a larger 460 carb on it so that filter might help it more than normal with the stock zama. The HD filter works well at keeping fines out but clogs quickly.
malk315
9:15 AM
Lancaster, MA
And I'll correct myself -- it's the "Maxflow" filter to try. No cover... just bolt on the foam and give her a go.
I'll give this a shot w/ my hybrid next time I have it out.
Maybe I'll hit the sugarbush over the break and do some testing.
