ChipsFlyin
OPE Platinum Member
- 1:54 AM
- May 5, 2016
- Pittsburgh
Not for the little stuff. That will be my fun saw for biguns and gtgs.Your new hybdrid will soon take over! lol
That's what I do too, but I prefer the 50-70cc huskys for handling.Lol I like all the saws and brands really, Iove giving people some shizz over their preferences though
Sounds good to me.I'm in the process of doing a 54 cc Poulan to 038 mag hybrid. If everything goes ok it will end up at less than a 12 lb saw with 68 cc. Will not be a true 72 cc due to stroke difference. It will be my new regular camp saw. Weight of a saw is important to me.
Works great one minute, then it cuts in and out the next
I’m not giving up on it yet Joe, I want to get some more tanks through it and see if it comes around. It does run great.... sometimesSend me your serial number and coil part number Deets, I will flash a 48 and send it to you.
What do you have to loose? Asking for a friend...I’m not giving up on it yet Joe, I want to get some more tanks through it and see if it comes around. It does run great.... sometimes
I have a pile of pics with calapers showing measurements just in getting the cylinder and wrist pin to fit. I'll do a thread once completed. I hope it works out for me. It won't be done till winter. Too busy w other stuff.Build thread? I have a 2800 that could benefit from a p/c swap.
Nice room for moving the screw holes on the 38 cylinder. Once moved no room for screw heads. Had to use 10mm ID x 12mm OD x 10 mm bushings on the poulan wrist pin to fin on the 38 piston. There is still a pile of work. Need to trim the skirt so thrte us 20 thou clearance to the case. I don't have fancy tools so doing all by hand. Grind measure grind measure.... Have to do some work on the tank through hole for a larger boot plus... I'll get back to it some day.I would think it should make a snappy sporty runner with the short stroke as long as the port timing plays along well. What kind of obsticals did you run into getting it to fit?
