Saw video thread
Manofstihl066
9:47 AM
Georgia
Nice strong saw there Bradley. [emoji106]
I think the Stihl chain has much harder steel in the teeth than Oregon. Stihl holds the edge better.
Thanks Jeff, I was thinking that too. You can really tell a difference in the two when filing.
9:47 AM
Yup. I noticed the same thing.
Oregon is much easier to sharpen, but doesn't hold the edge as long. Carlton teeth are also very, very hard! I think even harder than Stihl.
Definitive Dave
Piss Rev Mafia Member
9:47 AM
Central Ohio
Dallas sent me this chain to test, I got to try it out on this Poulan Pro 415 that got a little work done in the Chaos Garage today.
Filtration on this saw sucks
Problem Solved
the piston and cylinder looked great, so i swapped in an unlimited coil, modified a clutch cover, tossed the brake, put on an 8 pin and a pull handle and did a little delicate exhaust surgery
it runs pretty good and one more project off the bench
Time's Standing Stihl
Below me...
9:47 AM
Central Iowa
Problem Solved
Nice scare tactics Dave! Saw sounds good, @dall did a good job on that chain
Definitive Dave
9:47 AM
Central Ohio
yep this is his 25/15 grind I think, it is nice and aggressive and I am going to run it on this pp415 and the stock Jonsered 2171 tomorrow, It felt really good on the Poolawn but I think i was a little fat when i watched the video, so it might be even a bit better when i learn how to tune a chainsaw :BangHead:
Brewz
1:47 AM
Hunter Valley - Australia
Day out cutting some of the hardest timber on earth today.
Ironbark and the (in Australia) legendary small leaf variety, dead, standing.
This stuff is rated at 16300 Jenka which puts it at 3 times that of oak etc.
Its like concrete and I have to halve or quarter 2 foot rounds so I can lift it into the trailer.
The 14" thick 2' rounds halved were only just pickup-able. Its like lead.
GCJenks204
"Special Buns"
8:47 AM
Winnipeg, MB
Great stuff Tony. Love to see that real life action.
Canadian farm boy
“Normal” people scare me.
9:47 AM
Ontario, Canada
Solid front cover is definitely quieter. The saw feels a bit more high strung with dual port front cover. Still works good but I'm liking the solid front cover better. Seems to have a touch more torque and it's a little better behaved.
The saw tuned very close to the same wot rpms with either cover.
Deets066
AKA Deetsey
9:47 AM
Now just modify your solid front cover with a small hole. Best of both worlds
Deets066
AKA Deetsey
9:47 AM
Well I went big with mine, but you can make it however you like.
The way I build saws they seem to do well with a lot of exhaust outlet. If I only go duals on the side they are usually large
9:47 AM
How loud is it when you run that? Louder than the dual port front cover?
GeorgiaVOL
9:47 AM
Columbus GA
Just got my PP335 going today. I need a better bar for it though. This one got a little hot even though it was lubeing just fine.
