Saw video thread
t4driller
Daddy Day Care
9:04 AM
Southwest pa
All 3 have the same case capacity.
I thought they did, was just making sure. It's gonna be another week or 2 til mines together. I decided to make it look a little better. Porting is all finished, just need to get it in gear and get the rest of it done. I've never ran a ported 066, I'm pretty anxious to run it..
Lightning Performance
9:04 AM
East of Philly
They all hum good. Nice work! Chasing that tunes a *b-word hu, with those oversized carbs. 1/8-to 1/4 that's PIA.
Did you make it out past 3/8 with stiffer spring?
Scraptor
Active OPE Member
10:04 AM
Nova Scotia
Have you tried to clean up the mahle cylinder or is it to far gone? I like the way you worked that piston.
It looks like mostly piston metal stuck to the inside of the Mahle jug, I scraped at it a little, and it looks like it would clean up.
I was wondering if a soaking in phosphoric acid would lift the deposits.
9:04 AM
Look up Randy's method. It's here somewhere.
I'd degrease and cautiously use muriatic acid on a Qtip. Then sand. I bet you're fine.
Your exhaust roof looks really square. Did you raise it?
Those jugs come in with a high exhaust anyway. Sanding the piston ain't gonna help that.
Clean up your OEM jug and we will help you get your saw running like it should again.
Take a look here
http://opeforum.com/threads/my-buddy-daves-ms260-and-an-am-vs-oem-jug-comparison.2606/
jmssaws
Banneded
8:04 AM
So Jason,
What makes lasbajohn's porting different? Better factory jug?
I didn't time them, but the 56/64 looked faster in that big wood.
I see your working on your legs. Where they thinner for Laslabjon's build?
Porting is no different than any other.
It is the best stock cylinder I've ported for sure.
I think it beats the 056 by a second or so
jmssaws
Banneded
8:04 AM
The 066 will tune 2k faster than it is in the video. According to the timing it has to much intake and exhaust duration to run a long bar but evidently a number is just a number.
In the last year I've learned there are other things that are as if not more important than a number.
9:04 AM
Like keeping your ankles thin
