Saw video thread
8:46 AM
how can you tell a 046 cylinder apart from a 460 cylinder ?
Other than the 046-D cylinders, I know of no way to tell the difference, but others may know more than I do.
I have a stock 460 jug that Dr Al says looks like a ported saw, but we did not check the timing of the ports on it, but Al was impressed with the look of it. I did not get to run it with that jug on it.
jmssaws
Banneded
7:46 AM
My experience has been that most 046s don't run much different than 460s, the exception being the 1st year 046-D jugs.
My 046 would not out cut my 044 till I got it ported, IMO, porting makes a big difference on those saws. (at the time both saws had dp muff cover and HD-2 filter, but had not done the timing advance or gasket delete to either saw).
I'm not sure how much difference a gasket delete would make on an 046 or 460, but my 044 and 440 have really responded to it.
Both my ported 460s have 046-D jugs, and I think they are even just a hair stronger. I hear the D jug results in about an extra 10 psi, plus I think (in general) they came with better stock port timing.
I never really got into them but they do make big gains ported.
There a perfect saw for a popup.
No need to lower the exhaust port.
Deets066
AKA Deetsey
8:46 AM
As far as compression goes with D jugs.
I put a 46 D in my hybrid, base gasket delete and shaved .022 off the base.
Chainsaw Jim
Con Artist LLC
5:46 AM
Springfield Oregon
I just finished up this 12mm no decomp 044 today. I'm very glad I didn't fatten the squish band as it's a knuckle buster as it is.
These are the first cuts after initial tuning so there is going to be a good improvement once the rings set. The chain is from my 064/066 hybrid so the rakers are way too low for this saw.
