Saw video thread
jmssaws
Banneded
3:58 PM
Here's a muffler modded stock 066 against mine for comparison. Stock one is a good running saw,should like porting
S Tebo
4:58 PM
Maryland
Okay, I'm jumping in...
Nothing crazy, just some test & tune cutting while also gathering firewood for the fall.
Cheers!
Scott
MMWS 261OE
MMWS MS460R
MMWS 044R 10mm
038 Mag II
029 AV Super
paragonbuilder
4:58 PM
Norwich, CT
why for does you cuts da styrophoam my lad?
I bought like 50 sheets of 3-1/2" sips panels that had been left out and were rotten for $100. I cut the osb plywood off so I can use the foam to insulate my shop. With 2" being $40 I figured it would be worth it. At first I tried just prying the plywood off. It took me almost an hour per sheet. I was ready to toss it. Cutting it with a chainsaw was my dads idea. Worked great! I got them all cut in like 6 hours. So I made $2000 today... Sort of....
Redfin
Meh...
4:58 PM
Central Pa
Did you not have the room just to leave the plywood on?
paragonbuilder
4:58 PM
Norwich, CT
What oil ratio and raked depth ya running on the styrofoam?
Hand filed?
50/1 klotz
.025
Yes hand filed. But not recently.
I did a tree job a couple weeks ago and ended stumping a 48" oak.
I havent sharpened it. It was just foam and I didn't know what might be in there.
