Saw video thread
Frank bierce
2:40 AM
Oregon
I opened the chamber on the bb hybrid and got compression down to 205lb,it helped but still needs less.
The oem hybrid is a good bit ahead still
Oem definitely sound more throaty...compared to the tinny sound of the am cylinder. Did you try the am without any work? Curious what kind of a difference you have made
jmssaws
Banneded
4:40 AM
No I didn't try it stock.
It doesn't run bad it just doesn't run like the oem saw.
I'll get compression down to where the oem saw is and try the exhaust and transfers at the same height and see how it does then.
X 66 stang347 X
5:40 AM
Georgia
So you want the bb saw around 175? Is that due to the sump volume on the 044. A ported 460 you run around 200
Frank bierce
2:40 AM
Oregon
I'll be watching :)
jmssaws
Banneded
4:40 AM
The oem saw is bout 180-185 but I was trying to get 190.
I think compression will hurt the bb saw more simply because the bore is bigger.
Might need less on it than the oem saw.
The bb saw isn't timed ideal either.
Definitive Dave
Piss Rev Mafia Member
5:40 AM
Central Ohio
I am trying to keep this straight in my head :)
Both are an MS440 base saw right?
OEM is a Stihl 046/MS460 cylinder and the AMBB is an 046/MS460 BB at 54mm?
jmssaws
Banneded
4:40 AM
MS440 double big bore :)
Make that puppy run like an 066 with the weight of the 044, that would be sooooo sweet!!
That's gonna be difficult,hell I can't make it run with a 044 hybrid much less a 066. Lol
I like your thinking though dave.
Need to find a bigger carb
