bikemike
- 9:21 AM
- Feb 4, 2016
- Cottage grove mn
You might have the nice weather but we have cheeper prices on saw parts lolBeer drinkin weather here
A chainsaw is balanced regardless of piston weight.
I have balanced hundreds of 4,6,&8 cylinder engines. On "V"engines we always used "bobweights" in the crank journals to simulate the weight of rod/piston/rings/bearing. The bobweight was calculated by first weight matching all components then adding the weight of all rotating components(rod bearing & big end of rod) to 50% of the reciprocating components (small end of rod, piston,pin,rings,and a few grams for oil). That number is what you make the "bobweight" .Have you ever heard of "blueprinting" or "balancing" a four-stroke racing engine? I have done it, and it involves weighing the pistons and making the counterweights on the crank match the weight of the pistons, as measured by the balancing machine.
The amount by which we change a saw piston is almost inconsequential at the speed which it runs; try it on saw with no anti-vibe though, and you will have a different view.
I'll throw a boxer or a opposed motor in the mix. The opposing piston balances each other.![]()
The cams for the 302 change to the 351W firing order. The 5.0 HO also has the 351W firing order.Yep. Like the original cam that was in my 68' 302. Swap to a newer cam and it changed. Supposedly it's easier on the bearings
Lot of cams for race cars switch firing order.
The coyote has the old flathead firing order. It is funny after all these years they went back to that because it is the best.
Sent from my SPH-L710 using Tapatalk
Too bad Ford never made one like that.I use to have a short bed single cab ranger with a H.O and and t-5 with a explorer rearend with lockers. Fun truck![]()
Google "Newton's 3 laws of motion" for a very interesting and informative read.If piston weight changes balance then a 066 with a much heavier 288 piston and bearing and wrist pin and shims would certainly shake it's self apart or a 044/046
OR a 064/066 and stihl done that one themselves.
In a multiple cylinder motor piston weight does affect balance but not in a single cylinder.
Maybe that's why nobody has ever balanced one?
All it can do is change the load that the crank is moving and that cant possibly affect balance or revving the saw or a light load or heavy load would throw balance off.
Chuck a crank up and hold the rod tight with a bungee strap and spin it.
