Nutball
- 12:37 PM
- Oct 31, 2018
- Mt. Juliet, TN
What kind of wood?MS880
Frozen poplarWhat kind of wood?
Do you know what variety? Doesn't look like balsam or tulip. I have a mystery wood that looks similar I'm trying to IDFrozen poplar
I’m not sure the variety. I have random logs dropped off from a tree guy I do saw work for.Do you know what variety? Doesn't look like balsam or tulip. I have a mystery wood that looks similar I'm trying to ID
They both run well.Both saws are using the same chain, a handfile by me that is a bit too aggressive on the rakers, you can see me struggle a bit.
Both saws are stock porting, with only a couple things like base gasket delete.
440 clone has 155 psi
61 is wearing a closed port cylinder and has 210 psi
@MustangMike - thanks, I was hoping the 61 would have kept up a bit better. Im going to work on that!
Do you think porting could get it past my clone? Or would I need a bigger bore plus porting?
Yeah, but at least it's easy to go back if he tries and doesn't like it.I'll bet that baffled 460 muffler improved the torque on that 440. That being the case, maybe leave the timing where it is.
