Saw horse plans
jakethesnake
I Am The Snake
5:22 AM
Here & Now
View attachment 20351 If y'all haven't tried these give em a go they hold very well and have a torx head that will NOT slip all I buy anymore
Obviously has nothing to do with a saw horse less you wanna use em to put the horse together.... They come in all sizes and they're all pretty pricey but they're good enough my tight ass buys em
cantgitright
i am Mastermind's other profile
5:22 AM
right place at the wrong time
I run square drive for 99% of what I use
and we have a local store that just sells/makes screws bolts and hardware, they have about any and every kind of screw made...a 1/4 keg (2000 pcs for the #9 x 3") probably cost close to what a 5lb box would cost from anywhere else
jakethesnake
I Am The Snake
5:22 AM
Here & Now
You ship that stuff? I could re up
junkman
Crush it
2:22 AM
pacific northwest
Those deck screws will kill a sawzall blade if try to cut one ,i buy them by the big box ,3 inch ones the square head ones are a little thicker than the torx ones at my local store .
P.M.P.
Stiff Member
5:22 AM
Michigan
I gots me some hammered together and believe they would have held a truck in there prime.
Seen some plans for some back in the ninety's used studs from a church remodeling job.
Should get some pics for ya.
I made these in the mid 90's they are 35" tall and 4' wide
Jimmy in NC
5:22 AM
North Carolina
Brian,this is roughly what we would knock out on framing jobs out of cutoffs. Usually used plywood gussets at the top. The inverted "T" sets the angle right and you can splay the legs toward the ends to get a broader foot print.
All we ever used when i was building houses. New set every house...
Genius
First member of ASlite to receive a infraction
5:22 AM
Uncle Willys basement
They're better than the square drive too the square is ok Phillips will work but I avoid em. I still use Phillips for dry wall work But to build stuff Those are special
Those torx drive construction screws are all I ever use too. I love those things so much better than square and phillips too.
Jeff Svoboda
5:22 AM
Buchanan mi
@junkman if you're still looking for plans and can wait I'll probably be over at my parents tomorrow and my dad has built a few sets. Very basic. No more than 2by some plywood and chisels. Let me know and I'll take some pictures while I'm over there.
junkman
Crush it
2:22 AM
pacific northwest
I am still brainstorming a set ,so that would be great .
