Saw builds
Mattyo
Youtube speciawist
10:12 PM
Farmington, CT
i'm not remotely close to starting it, just milled the case, and will check squish soon, then get numbers and port... like building the parthenon this one... a real job
Lightning Performance
10:12 PM
East of Philly
I don't know,the saw I'm using is around 200 or 210 I'm guessing I've never checked it. I think it will vary from saw to saw, flywheels and coils will vary from saw to saw.
IMO for best performance every saw will need to be individually tweaked for ignition timing and tested. A few I did needed to be set back with a long bar and full comp chain. They were not from this model or blend there of. 60-75 cc class running a bar not recommended for that size. I just try to do what is asked of me by the saws owner and not what is recommended :-)
If it can be done it is always worth trying.
Anybody else ever put serious thought into why almost every 066 and 660 cylinder is timed different? No way they changed them intentionally that often.
I can't recall ever seeing 2 alike,lots close but not the same. It's not possible to change castings that much.
Good question! I got nuttin...
My guess would be that there's a lot of moulds used in the manufacturing process. Each one is just a shade different but still in spec. So out the door they go. I'd bet that Stihl never gave it a thought that someone would actually be checking the timing on them.
How could they F-up that bad??? I would think that is the most critical of all manufacturing processes is to get the "mold" or core shift right? no?... Can't make chicken salad with chicken *s-word.
The silly little muffler hole makes all that silly stuff like port timing go away in a big hurry. Jason should try his worst runners out with a stock muffler and see if they revert back to a near stock running saw. I'm going to try it with this 044-046 builds coming up. Something keeps telling me to give that a try. You can not get out what you can not get it.
I'd drive a little screwdriver in it on the edge and pop it out then straighten the edge back up.
I haven't done it in 20 years but back then I would make or reuse everything I could and I learned a lot from doing that.
Lots of time the pto side seal can be popped out with little damage to it.
I'm with you there.
Case in point. my first 029 build was two junkers in a crate with one complete burnt saw. I bought nothing but a set of rings and had some sealer handy. I needed to learn what was what and the whys of why it was what it is. Learned more about saws that day than ever before.
People laugh when you said, "I reuse", I did not. I know the lesson you learned by doing the same things when we were youngins. We had no resources and were broke to boot. If you had money and resources than you must have been looking for a learning experience like I was back then. I was cheap with my own toys. I paid the price sometimes with scattered or melted parts. The study of used or trashed parts is lost in most of todays teaching methods. That's how we got too many parts changers and not enough good diagnostic people in the repair industry these days. Most general repair mechanics today would not know that most used flywheel side seals are quite serviceable because they usually don't get looked at or studied at all. Rip out, replace, next :facepalm:
I'd bet some of those seals you swapped around are still in service today :-)
jmssaws
Banneded
9:12 PM
I have worked on saws for 20 years and have never seen a crank seal that was bad when the bearing wasn't bad too.
I had one brand new saw that had a seal with no spring from the factory but that's it. I've built lots of box saws that have sit for 10 years or more and If the bearings were good so were the seals.
A large percentage of the seals changed have nothing wrong with them,most times its a carb problem or a tune problem.
jmssaws
Banneded
9:12 PM
@jmssaws I can't hear any more. Thanks. Also...I like your saw. Thanks for lettin deeter keep it.
It's not that loud is it?
My 066 is loud,Mikes 346 is loud.
I'm glad you liked it,I've had that saw since new and it's always been my favorite and has always been a runner,I learned to port on that saw,it's probably had 15 or 20 different cylinders on it in the last 10 years.
big t double
You can call me Teddy Eastwood.....
9:12 PM
I didn't notice the big fuggin hole in the front cover till after we were bullshittin a bit...the muffler is pretty much just for looks at this point no? It is a beast:dancer2:
exSW
'Cause Thomas is a poopyhead
10:12 PM
United States
Define bad bearing. I've had two saws in the last six months that the last thing I did was change the seals. End of problem. I'm no saw tech don't pretend to be one. So are these saw's seals going to fail again in short order due to bad bearings?
jmssaws
Banneded
9:12 PM
It's certainly possible it was just a bad seal.
A bearing with a little slop will eat seals so will tight dull chains.
Chainsaw Jim
Con Artist LLC
7:12 PM
Springfield Oregon
I've seen bad seals and good bearings more than once.
10:12 PM
East of Philly
I've had wasted bearings and seals were still good. Those ones always make me scratch muh head a bit. I'd bet those were just a band fix by someone.
This is a damn good thread and so is Jason's other one.
Keep up the GOOD WORK Jay!
Spock out
Tor R
Novice, Leg model #2
4:12 AM
Mandal
Always nice to se tricks, but why doesnt your guys make a sleeve for installing those difficult seals, or using thin plastic as sleeve guide?
