066 bar stud
wavyoak
OPE Member
7:12 AM
Sacramento Ca
Anybody know what size helicoil it takes for a 066 bar stud?
Thanks guys.
two4spooky
8:12 AM
Southeast
Yes, there is an OEM repair (over-sized) stud for this. Do not drill out or use other methods, you may lose the easy options. Stihl has over-sized bar studs for repair of stripped case side bar studs for several series. Google is your friend here
ZeroJunk
9:12 AM
Browns Summit N.C.
I'm thinking the replacement studs are for plastic case clam shell saws. I have a drawer full of them.
If you want to go larger in to magnesium I think you will need to tap it. Like using an 056 Magnum stud and re-tapping it.
Well, guy on eBay has a Stihl part number for an oversize magnesium case stud. So,
