Brewz
- 7:16 PM
- Jan 16, 2016
- Hunter Valley - Australia
The poly flywheel is a direct match for the 064 shaft taper. There's the little plastic rim on the backside that needs trimmed down about a millimeter so it seats all the way down without bumping into the case. I'm sure there are other coils that will work with this flywheel that match the case bolt pattern better but here is a pic of an 1128 with a notch taken out of the bolt hole to give it something to hold it down.View attachment 26817
Thanks Jim.
I assume an unlimited 066 coil will give the correct spark timing. It will bolt on to the factory holes.
