S10 4.3l won't accelerate
paragonbuilder
12:30 PM
Norwich, CT
Rep for all involved.
I still have trouble believing I was wrong..........
LOL
I'm so freakin happy right now! You guys have no idea...
I would have thrown another $500 at it and still been like wtf! I didn't believe it would help... Lol... But I did it cuz I said I would... You guys are awesome!!! Thank you.
paragonbuilder
12:30 PM
Norwich, CT
Glad "we" found the problem !
Now take it out and safely give it a Mexican tune up to clean that carbon out .
I know a few people had mentioned it so without looking back I'm super grateful and humbled that I was skeptical about this.
Just got to gut these cats now...
Canadian farm boy
“Normal” people scare me.
12:30 PM
Ontario, Canada
I'm glad you found a problem.
Just to be safe I would replace to pre cat o2 sensor (they do become "lazy" as they age) I would also double check your fuel pressure. You mentioned having 60 psi at idle. That is around the minimum pressure spec for the vortec engines.
Canadian farm boy
12:30 PM
Ontario, Canada
With your fuel pressure gauge connected and the engine idling slowly pinch off your fuel return line. Don't pinch it off totally. You should see your fuel pressure begin to rise as you pinch of the return line.
paragonbuilder
12:30 PM
Norwich, CT
In my experience a plugged cat usually happens as a result of some other issue. Think of it like a saw running really rich and plugging the screens.
Yup! Just talked to my buddy at Napa. He said same thing. Probably running a little lean from low pressure caused it. But the question is was it the injection system which I replaced already right before this happened.
Also he says if you delete the cats, you can put a spark plug defouler on the secondary 02 sensor and it will usually prevent the codes.
Canadian farm boy
12:30 PM
Ontario, Canada
The low fuel pressure will cause the injectors to have a poor spray pattern( the fuel mist won't be as atomized). The fuel won't burn completely and you will get a lot of soot. Also a lazy pre cat o2 sensor will essentially call for extra fuel causing the engine to run rich. This too will make your exhaust overly sooty. Both these issues will cause poor performance and bad fuel economy.
concretegrazer
11:30 AM
Mo
Glad you're getting somewhere. I haven't played with gassers in 15 years so I'm no help.
In my experience 9 out of 10 fuel pumps will just quit working all together but there is always that 1 that will still sorta work. I'm leaning towards you have that 1 just like I did.
& then there's the really odd duck. Had a friends 97 that wouldn't start but would run flawlessly. Still baffled at that one.
paragonbuilder
12:30 PM
Norwich, CT
Once I get this exhaust sorted I'll look closer at the rest. I didn't want to dump any more money into it till I figured out the issue...
Now I'm pretty sure I can make it into a good running truck I don't mind spending a little money
Nitehawk55
12:30 PM
Ontario
I had a 97 chev pick up with the 4.3 , they are an awesome engine when running right and you can put a lot of miles on them .
5.7 Chev V8 with 2 cyls removed , simple design that worked well .
You'll likely get better performance and mileage that you didn't know it had .
