paragonbuilder
- 7:37 AM
- Jan 2, 2016
- Norwich, CT
It'll never run right with plugs that fouled. If you drop below 60 psi then injectors may. Or spray properly causing it to foul plugs. Psi should raise up at least 5 psi or maybe re when you throttle it. Has it ever had an intake gasket replaced. If answer is no it needs to be replaced. They all go bad on the 4.3 and it can run lean from sucking on bottom side of intake
I'm not sure if it's been replaced. I bought the truck last Oct.
