S10 4.3l won't accelerate
jmssaws
Banneded
11:25 AM
Is it mass air?
Sounds exactly like one that the mass air meter is unplugged on
jmssaws
Banneded
11:25 AM
You check the wires going to the mass air?
ABarrick
TacomaTRD98 on AS
12:25 PM
Newville, PA
Does it idle "perfect" or is it labored or rough in any way? If you unplug a sensor while it's running it will typically stall. If you cycle the key it should restart(ses lamp will be on) and run. It may not run perfectly but atleast run. If the unplugged part was giving an erroneous resding, it should run better than when it was plugged in. MAF are notoriously junk on those vehicles. TPS could be wacking out too. IAT reading and ECT readings could off and messing with fuel trims too.
If you very carefully ease the throttle open does it instantly stall or will it pick up some rpms?
Dumb question, did you just get gas? How cold is it in your neck of the woods and is it parked outside? Could be a partially frozen/ restricted fuel line. Could be letting enough through to idle but no more.
Cutforfun
9:25 AM
Palmer mill
Fuel pump is my bet, I have a 4.3 in my Toyota and had the same problems, it would idle fine and run good for about 10 seconds when you revved it up then it would fall on its face and almost die. It was actually the fuel filter in the tank at, the pump filter had rotted off and was sucking crap from the bottom of the tank and starving it for fuel. But it needed 45psi to run right.
