Ronie
I haven't seen a build thread in awhile so I thought I'd make one on this Echo 600 that I'm attempting to put a MS440 cylinder on. So far I've got the cylinder where it will bolt up and opened up the piston so that it will fit on the rod, using a MS440 bearing. The pic with the red circle is where I had to cut the fins so that it would fit around the AV mount.
