Rebuilding The JMS 064
GCJenks204
"Special Buns"
2:48 AM
Winnipeg, MB
It just baffles the crap out of me that the port work can be so good, and EVERYTHING else is crap!!!
I'm starting to suspect a twin locked in the attic! There is just something not right about this whole thing.
It suspect he does the grinding straight and then once he's done gets high and finishes the rest out of his tree.
Time's Standing Stihl
Below me...
3:48 AM
Central Iowa
Randy those rivets ain't a big deal. I could always put those on later. You and the fellas here have done more than enough. That plate ain't goin anywhere, whatever he glued it on with holds strong.... I tried to peel it up and couldn't.
You run this saw yet Brad?
2:48 AM
Well maybe you will get to run it at the gtg?? Hopefully...
Yeah.......it will be ready.
I just got the clutch and drum a few days ago. It runs great........but the chain wouldn't stop spinning at idle. I tried new springs, then different springs, then without the washer........nothing helped.
So.......I just ordered a new clutch, and a new drum. OEM of course. :)
Lightning Performance
3:48 AM
East of Philly
Were the spring pockets all bagged out where they ride in the shoe?
Below me...
3:48 AM
Central Iowa
Lol, that's the same issues I had with that topend I got from you for my 64.
A new Clutch still didn't fix it. ...
2:48 AM
Put 10 different clutches, took the washer on and off, Different Bearings and still nothing. Changed a few carbs out and still nothing changed.
@srcarr52 ended up changing the pop off pressure at the Iowa gtg and fixed it
Shaun is a smart feller.
