jake wells
no longer here
- 11:21 AM
- Dec 28, 2015
- ky
its a wonder.No new clutch was needed.......
Looks awesome
tell him to use 16:1 so it will outlast him.After a few tanks it should really start coming alive. It's all sorta tight right now.
That just had some really good numbers in it........I did very little grinding.
Runs great Randy! Give her some more fuel when u tweaked it?
*f-word thattell him to use 16:1 so it will outlast him.
Sounded like itRuns great Randy! Give her some more fuel when u tweaked it?
Somewhere around 103-120-74 stock?After a few tanks it should really start coming alive. It's all sorta tight right now.
28" bar. He's had that bar many years lolNice job there Randy, great to see one of those great saws come back to life.
What length bar is that?
Every time I run my MS440 (like yesterday) I mentally thank you, as I just bought a new piston, cleaned the cylinder using your method, and basically reclaimed a low hour saw from the dead! It even came to me with brand new HD-2, fuel filter & plug. I presume they lean burned it after tuning it (Hi was set 1/4 turn out instead of Low).
Perfect numbers for that saw.Yes sir. It was running 15200 or so. Took it down to 14600.
I didn't check it before machine work. The transfers were at 122 after. Ended up 102\122\78
I like a fuzz more intake, but either way will run great
78 is the universal stihl good intake numberI agree that more intake might give it a little more snot. I tend to think about fuel usage, and idle quality maybe a little more than I need too.
I'm hung up on building "the perfect work saw".
LOL
