- 8:38 PM
- Jan 12, 2016
- Iowa City
I took the 550xp apart and I was searching for bearings that were a steel case replacement... I settled for a set of Timken bearings, 6202 2RS C3... stock bearings are 35mm 15mm 12mm single seal...
where as the Timken bearings are a double seal that measure35mm 15mm 11mm... I figured not a big deal 1mm difference... (12mm = .472" vs 11mm = .432") I'll just machine a spacer to go between the bearings and the case as well as a smaller spacer for the clutch side to keep the proper spacing.
I was wondering if anybody has done this? In theory, it should work just fine.
The OEM bearings will last a long time when running 40:1... 50:1 is the cause of most of their demise.
Great score btw!
