HUSQVARNA Post your favorite 2series Husky.
SawTroll
Information collector
12:19 PM
Troms, North Norway
They got the bigger carb in 85-06, XP decal on top cover 86-01 and finaly XP decal on start cover in 86-12.
I went through this to figure out when my 266 was made, eventually I figured out it was made late 86 or early 87 due all those things + crankshaft number :)
You are right, the carb change did happen before the designation changed to XP.
The dates you listed are of course the IPL dates, which doesn't necessarily correspond exactly with the date a change happened.
SawTroll
12:19 PM
Troms, North Norway
I believe I saw Niko say that for a while they were made with the se on the starter and XP on the top at the same time.
About the same happened with the 181 as well (before it became the 281xp) + it happened (CD/XP) at two different occasions with the 2100, first for a while in 1979/80 (at least in marketing) and then in 1987, right before it became the 2101xp..
Simondo
11:19 AM
UK
I believe they were for a short time...Tor listed more or less when this was happening . As I'm learning from Niko, there is a bit of a grey aria in the IPL dates ...:D
SawTroll
12:19 PM
Troms, North Norway
Thats the changes I found as well...the bigger carb with XP is a help in dating ...as long as its not a SE with the 2 things changed . ..Then like you with crank numbers , a bit more digging is needed.
I was always of the opinion the SE and XP were different as the RPM's that are not rated the same as likely due to the carb ...but it was put by someone on another forum i belong to , that they were "ALL " the same SE or XP . I don't mean ST by the way !!:)
That is true only with the saws made after about 1985-06, and only when it comes to power/rpm specs - of course there were other changes over the years, there always were/are.
What is true is that it is the production date that tells how the saw originally was, and not the se or xp designation.
SawTroll
12:19 PM
Troms, North Norway
Yes, each new IPL usually sums up the changes made since the last one - but of course there are exceptions from that as well, like if there was a large stock at hand of the old part. More detailed info was available to dealers, in the Service Bulletins.
In some cases it also matters that IPLs are about replacement (spare) parts, and not necessarily about what was/is in the production saws. As an exemple, some saws in this "family" came with (similar size) Walbro carbs, but it always was the Tilly carbs that was listed in the IPLs. The policy regarding such details have of course changed over time.
Simondo
11:19 AM
UK
Out of interest and if you don't mind saying.....do you have a lot of paperwork issued to the dealer network as well as access to the electronic database material issued to dealers as well?
Your tag as "Information Collector" would suggest a serious library of information as a interest or profession .
SawTroll
12:19 PM
Troms, North Norway
I once had such an access to the Husky and Jonsered stuff, but it wasn't "legit", and I lost it when they changed the passwords to something less obvious. In retrospect it is a pity that I didn't copy and save more than I did (service bulletins that is, the IPLs are still available both at the brand website (not in all nations, and which ones varies)) and elsewhere. The Husky library goes back to 1972 or so, and the Jonsered one to the late 1980s (+/-), when Husky took full control of the production.
A lot of information does of course turn up trough different forums, and some times Google is useful.
Simondo
11:19 AM
UK
I tend to use Barrett's (Small Engines) IPL and Tor put me onto "Parts Tree" and have IPL pages saved for common saws i work on...Both have been Very helpful in tracking down parts so I'm ready to quote numbers to my suppliers who have all the Husq dealer information. Ordering parts is "dead time " money wise mostly.
Don't worry...your secret of "international espionage" is safe :D
Toad22t
5:19 AM
Central Wisconsin
+1 on parts tree! They are also helpful when you look up the part that your looking for. Once you open the next page it tells you what other saw's it came on. It's alot easier to ask for parts for lets say a L65 then a 2100/298/2101.
SawTroll
12:19 PM
Troms, North Norway
Yes, I use those as well.
Tor R
Novice, Leg model #2
12:19 PM
Mandal
I'm big fan of parts tree, probleby learned more there compared to study IPL's, why I got one 50 and 55, figured out I could use several parts from them to 254/262 thanks to parts tree.
Unfortantly I think they rebuilding their site nowadays, before we could follow old parts and new parts seperate...
Warped5
5:19 AM
Northwest IN
I'm a big fan as well. Also a big fan of www.ereplacementparts.com ... the parts xref is very helpful.
Warped5
5:19 AM
Northwest IN
Ok, I'm following this thread for 18 pages now so might as well post my 262.
Built from mostly NOS parts. It's a 1990 model; has the KS cylinder, the HDA-87 carb and NOS piston. Not yet one full tank through it.
Simondo
11:19 AM
UK
Very Tasty Sir !! Built as a user ?
