Porting a ms460
6:23 PM
Factory or from an engine builder?
6:23 PM
Still got it, was just checking it over today. However, based on how that 046-D saw runs, no regrets! But I guess I gotta find the carb spit back baffle ... but hard to imagine it will actually run stronger!
Sooner or later, I will use that jug on a 440 or 460, but we never did check the timing of the ports.
X 66 stang347 X
6:23 PM
Georgia
I'm going to have to follow this build. I just got through with my 460 porting. And When you say early 460 Mahle cyl. When did that end? My 05' had stihl on one side of the cyl base and Mahle on other side.
jmssaws
Banneded
5:23 PM
I have no idea when they stopped, maybe 01 or whenever the mahle stopped in the 066
jmssaws
Banneded
5:23 PM
Cut 030 from the base and 020 from the chamber,
Got a few hours of grinding to do then I'll see if it can handle my old 460.
X 66 stang347 X
6:23 PM
Georgia
Ok.My squish was at .025 when started and that would lower it to 15 with factory gasket. What I did do was cleaned up and blended the transfers toward the base. Shaved .007 off the base wth Dykem, a piece of glass and sandpaper and that gave me .018 squish.
Cleaned up and smoothed the intake with a sanding roll.
Opened up the exhaust 1.3mm on both sides
And bumped the timing up 7°.
I have yet to have a chance to tune it much in wood yet. But it was running rich at 14,200. How much more would I gain if I take some off the chamber and base? Thanks for the tip
6:23 PM
Nice! Very shiney shiney.
