Scott0154
Feral member
- 3:09 PM
- Jan 26, 2016
- Central Valley Ca
		Mine tops out at 13,000-13,100 with the new coilThis is the new unlimited module (coil) I put on my MMWS ported 661 works greatView attachment 16487
		Is it the same part # as mine because mine pulls harder than with the stock coil iam taking my saw to my dealer on saturday to put it on there computer to see what RPM its pulling saw was running a little lean after a long cut for a few seconds until it settled down no problems now though the coil did change the fuel parametersMine tops out at 13,000-13,100 with the new coil
		How old is your saw? Just curious as mine is an early model and it no way would hit 13000 even let alone 13900. Mine sounds more like 12 to my ear.I just got 13920 on a stock 661 with mtronic on my tto tach. If i can figure out how to post a video i will
		On a 661 it doesdoes the maxflow fit back under the stock cover?
I'll fix you up with one.so basically if I take an old HD! and take the media out of it and wrap the maxflow filter around it I should be good right? What actually holds the filter tight?
Or should I know get another 661 filter and modify it for the MAX flow system?
Still anxiously waiting for the 661 MAX flow kits to be released....
		Hey man don't short yourself!!! If you need me to send filter or piston let me know lolI'll fix you up with one.
I don't have PayPal. Send me the green maxflow filter, don't need anything else.Hey man don't short yourself!!! If you need me to send filter or piston let me know lol
Can you pm me your paypal?
