ported 661 with a carb
sawmikaze
2:02 PM
steeltown
Did you have to buy the whole set up with the cover to get that plate?
Its 2 plates , it doesnt work with just the one the knob goes through..you need both , call madsens.
sawmikaze
2:02 PM
steeltown
I'm only using one plate on my 044, 066, and 661 saws ................. why the 2 plates Ryan ?
On the HD2 theres too much room behind the plate from the filter knob is the best way i can describe it...if you only use 1 plate it spins around like a prop..try it..ull see what i mean..thats on a 461.
On the max flow it doesnt seem to matter.
sawmikaze
2:02 PM
steeltown
20160328_112719.jpgThis needs to go on first if you wanna use the plates on the HD2
Otherwise the plate wont push the filter down without the first one on..i stuck a screwdriver behind it to kinda give you an idea what i mean..and thats with the nut threaded the whole way..with just that plate it spins like a fan.
sawmikaze
2:02 PM
steeltown
You will pick up what im puttin down if you try it on a 440/460/660.
Idk on a 661.
Moparmyway
Its just a saw
2:02 PM
In a meeting
Idk on a 661.
I've got Max Flows on my 44's, 66's, and 661 ................. I understand you get this problem with HD2, but I would just use a washer
sawmikaze
2:02 PM
steeltown
I've got Max Flows on my 44's, 66's, and 661 ................. I suppose you get this problem with HD2, but I would just use a washer
They gave it to me in the 460 kits ive gotten..they gave it..ill use it.
junkman
Crush it
11:02 AM
pacific northwest
Why do you guys take the plastic covers off the air filters ? Seems like if a branch hit it or a log round hit it would crush the filter easier ?
sawmikaze
2:02 PM
steeltown
I tried the outerwear under the stock cover with an HD2 and my filter was plugged in one tank of gas.
I tried the HD2 with the outerwear under the max flow cover..it was a little better but not much.
We did a big yard poplar and an ash removal last week and i tried the plates with the HD2 and the outer wear and it was the best thing ive tried yet as far as the stock filter goes.
Moparmyway
Its just a saw
2:02 PM
In a meeting
I went 24 tanks without even blowing off that MaxFlow when I ran without a cover.
When using the cover, it gets packed with chips every tank
junkman
Crush it
11:02 AM
pacific northwest
Wood must be different than what i cut normally ,i do not have that problem ,can go all day before have to tap it out ,maybe my longer bar keeps the dust away from the powerhead ?
sawmikaze
2:02 PM
steeltown
Thats because they are bri-brids with triple port muffs !..awesome wood..awesome saws.
Buy a 362c...they are awesome too.
sawmikaze
2:02 PM
steeltown
why the orange plate on the hd2 ? cant you just put the filter nut on to hold it down ?
Why not use the plates if you have them ?
I bet usin those plates seals that filter to the base better than just usin the nut.
No brainer to this Jigga-Boo.
FYI - 044s are grate.
Deets066
AKA Deetsey
2:02 PM
I never understood what the other plate was for. Thanks for solvin that life long mystery for me, your my hero
:ole:
