paragonbuilder
- 12:41 AM
- Jan 2, 2016
- Norwich, CT
LolBuy Stihl its better![]()
you need one more category/selection in your poll,,,,Wow thanks for all comments guys , that's why a like this forum
That's what I have on mine also but have the mesh filter also to try.
Yes but its funny we are all debating which is better, the latest and greatest husky available or a 20 year old designed saw. To even be able to compare the two is a true testament to the greatness of the 262. If the av, fuel consuption, ease of starting and whatever else isnt superior on the 562 then Husqy has failed. Old muscle car vs new "muscle car". Both great saws just boils down to preference imo.
If buying a new 562 you should probably order one in direct from the factory to assure you're getting the most updated model possible. Aside from the problematic carb they have a problem with the plastic bearing cages and I suspect that's from the cages facing the wrong direction and they warp from heat. Every other saw model with those plastic bearing cages have them facing the other way and that problem doesn't occur as often if at all.
Ok so I'm just a crazy firewood cutter(not for hire) from the sticks that loves chainsaws, especially ported ones. I have or had stock 026's 16"and 262 18-20", a ported 254 18", 562 20", 371 25",stihl 460 25" and bigger saws 28"++++. I just can't seem to put down the 562. I have purposely not put any bigger bar than a 20" on the 562 just to keep saws around. Lol! But there will be a judgement day coming soon. I was one of those guys that hated the AT until I tried one. I know how to adjust carbs and make them run but the AT takes everything out of it. I was also scared about having to take it to the dealer for service, but there is plenty of knowledge through our sites to get beyond it and get it fixed. I actually have a husky dealer ask me now how to fix the hesitation issue's on the 562 because husky has given him the run around.
The 262 is a great saw with a great following. Husky has always had a stout 60cc class. Starting with the 161,61,262,357 and now 562. Any of those can make a great runner. Right now for the price of a nice clean 262 that is "25" years old there are better options out there. I guess it all comes down to what's affordable or what's in front of you.
I like the straight handle on the jred better tooReadily available parts...smoother..better balance..the list goes on.
Id get a 2260 personally but a 562 does it.
Best answer!Well that's exactly where I'm at , I'm going to keep the 261 and convert it being I have the parts to do so already. I found a good deal on a 562xp but it's ported and the el46 carb. I'm getting that then probably sell the one I like the least. Maybe keep it too
Winter??? Icing???? Doesn't Icing go on cake?????? LOLOL!!!The mesh filter is for winter to prevent icing.
I got the 562xp , it was ported but it doesn't look like it was radical which is fine, it's got a pop up piston but the base wasn't cut. The muffler I thought wasn't ported enough , I removed the entire baffle and painted with the ceramic header paint, it sounds mean now.
Before I worked on the muffler I ran 2 tanks through it. It's a fast saw that's for sure.
I thought I remember you said you paid $350.00 for it???? Ill give you your money back and a good 272 project saw!!! just kidding that looks like a Jim DandyI got the 562xp , it was ported but it doesn't look like it was radical which is fine, it's got a pop up piston but the base wasn't cut. The muffler I thought wasn't ported enough , I removed the entire baffle and painted with the ceramic header paint, it sounds mean now.
who ported?
