52mm bottom fed quad port should be pretty smooth imo and long bar capable.Stock is a bottom fed quad port.
But 7mm larger than stock bore size now. Next will be 9mm...
Maybe I jb weld the transfer cutouts and tighten the case even More?
One cylinder will be converted to bottom fed... Maybe quad port too...
Very nice lathe work.
you may be a little past 50% squish band area haha...
It'll buff out...you may be a little past 50% squish band area haha...
Tricky, but a diamond wheel on a straight hand piece is a trick many use for that.How to you get and keep the corners so tight on the uppers?
Joe’s porting is beautiful. And that’s “roughed in”
I would say Joe has a lot of talent .
wondering which company manufactured those jugsView attachment 228373
These had some tiny ports..
I sure am impressed with the plating quality, seems to be holding well and no flaking. Even when using the aluminum hog burr..
56 seems like the ragged edge for that con rod if you really make it scream. Time will tell.Thank you.
I will probably make 3 (52,54,56mm) that way if these other 2 saws run/hold up...
