Plastic Gas Jugs
Philbert
Chainsaw Enthusiast
4:06 AM
East Dakota
An empty, heavy gauge 'Tide' laundry bottle works well for bar and chain oil, with the drip-proof spouts - they come in different sizes too!
Maybe choose a white bottle (e.g. 'All') for winter weight oil?
The spouts can be pried out on most jugs to let you rinse them better (takes a few cycles to get out all of the suds). The label will come off of most jugs with lacquer thinner, or a heat gun (some).
I use a standard gas can for fuel mix so that there is no confusion. Also not sure how gas affects the plastic, and vice-versa.
Philbert
Ronaldo
4:06 AM
Eastern Iowa
Philbert
The laundry bottles do work for bar oil. I tried them with mix and the gasoline will start to swell and or shrink the lid, spout, etc. And believe it or not but after numerous rinses with warm water and then regular gasoline you will still smell the distinct odor of warm detergent. [emoji12] I used a fabric softener container once and only once...... strong odor wafting thru the woods. [emoji12] [emoji12] [emoji13]
Sent from my Z832 using Tapatalk
RI Chevy
5:06 AM
earth
I have a nice no spill gas can. I wanted to mix up a few different oils by the gallon to try out. I was just curious if anyone had experience with other gallon jugs. I will try a gallon oil jug. [emoji106]
czar800
5:06 AM
Ellwood City
You guys run your Saws??? :confused:
I have a few of those red jugs with the yellow spouts and really like them.
When I weedeat fence line I fill a pop bottle with mix and put it in my back pocket with a few feet of line. It gives me enough fuel to jump the fence and work backwards too the fuel can.
I rarely cut any wood very far from a truck or tractor.
Duane(Pa)
It's the chain...
5:06 AM
Centre County
You would not believe how nice these are to pour from. Not a single drop spilled. I have stored fuel in them for extended periods of time with no ill effects.
Farmchuck
5:06 AM
Nepa
1 gallon windshield washer fluid jug. Transparent so you can always see your gas & know it's got 2 cycle oil in it so you can't accidentally straight gas em!:):)
Farmchuck
5:06 AM
Nepa
5:06 AM
With one of these on top. 1/4 turn on/off. I removed the hose on mine
darkimpulse
Firewood Hack
6:06 AM
East Coast, Canada
Philbert
Great idea, going to use these for bar oil now on. Got the no spill for the gas mix and Iove it.
RI Chevy
5:06 AM
earth
For gas or oil Jake?
jake wells
no longer here
4:06 AM
ky
just don't let DOT aka Vehicle Enforcement catch you doing it because the fine is hefty!
you have been warned!
