Ketchup
Epoxy member
- 12:14 AM
- Mar 12, 2018
- Colorado
On my 362 I noticed the strato butterfly doesn't open till like half throttle, while most others seem combined and open at the same time? Could that be used as variable port timing? If the thought has any merit I can try it this spring, while I wait for the woods to dry up.
( I'm thinking that the closed butterfly will negate the lost vacum from an aggressive port timing)
I was just messing with my Strato Wild Thing. It’s just like the 362: cold air butterfly doesn’t open until mid throttle. I think it has to do with how hard the venturi pulls fuel at lower rpm. It must pull a lot more at WOT or the saw would just lean out and die.
Or it may indicate the cold air mixes more at lower RPM. If the air is just shooting through and out the exhaust as a block it wouldn’t lean out the saw as much.
