cuinrearview
Handy dood
- 5:42 AM
- Apr 16, 2019
- Dowling, MI
Reported.Strato saws are gay
Reported.
Ever since I laid my hands on a strato 261 I was wanting to use the tunnels for boost ports. This project really had nothing to do with gutting the stratos other than utilizing that real estate. Its on gas right now.I saw that in the porting artwork thread. Would you mind explaining it a little?
Is that a gutted strato intake with extra volume for Alternative fuel? What fuel is it for? What does the bigger circle hole below the transfers do?
Cool! What carb are you using now? I must assume a non strato type carb?Ever since I laid my hands on a strato 261 I was wanting to use the tunnels for boost ports. This project really had nothing to do with gutting the stratos other than utilizing that real estate. Its on gas right now.View attachment 281762
Reported.
I really like strato saws, much more run time per fill up compared to older saws.
So I've put a 562xp carb/intake on 550xp/545's and a 572xp carb/intake on a 562xp with very good results. Easy bolt on power. The question I can't get my head around is the fresh air charge. You can see in the following pic of a 550xp cylinder with the 562 intake traced out that everything is bigger. I opened up the intake to allow the bigger mixture to flow thru but I left the strato ports unchanged.
I'm thinking that the fresh air charge will need to be same no matter how much bigger the mixture charge is. Is this a concern or does it even matter? The thing I wanted to avoid is fresh air in the combustion chamber.
It probably wont matter, the strato ports are already much larger than they need to be as the tunnel in the piston is the biggest restriction.
IMO the strato duration vs. intake duration is very critical to achieve power in the RPM range you desire. The intake is filling the crankcase and the strato ports are back filling the long transfers with fresh air, so more strato duration pulls the fresh air further down the transfer port which then delays the actual fuel/air charge. If the fresh air isn't completely wasted out the exhaust then you have poor mixing of the fuel within the trapped volume. But adding intake duration to lessen the strato pull then decreases the crankcase compression which is much needed to provide ample pressure differential for the long transfer tunnels.
For the husky design the strato port timing is when the top of the piston tunnel starts to open the bottom of the transfer port, when this is happing the intake side is already open. So dropping the jug adds intake and strato duration at fairly equal amounts.
There's a book of info in this paragraph. I'm gonna have to go to the store and get a suitcase of Natty Light and start thinkin' about it.
I didn't think about the restriction being in the piston tunnels. I always worried about upsetting the case pressure and getting the timing of the fresh air slug off.
Unless you are looking for every percentage point you can find, just doing your machine work, and leaving the intake and strato ports unaltered is a sure bet. They will both gain some duration, and though the degrees of crankshaft rotation gained will be different on the degree wheel, it will work surprisingly well. With a lot of these units, you can grind more, and gain less.....
Strato saws are gay
Strato saws are gay
Throw about a 3hp shot of nos at er and see if she sticks. Whats the worst that could happen
