Oregon Bar weights
2:28 AM
Oregon Laser Tip hard nose , 20" 3/8" .50" 72DL D009 , part number 200ATMD009 , mildly used (I wore out one chain)
I am running .404" on it, takes 65DL with a 7 tooth sprocket on my Dolmar PS-7900
Oregon LaserTip D009 (200ATMD009)_1.JPG Oregon LaserTip D009 (200ATMD009)_2.JPG Oregon LaserTip D009 (200ATMD009)_4.JPG
2:28 AM
Oregon PowerSharp , 14" 3/8" Low Profile .050" 52DL A041 , part number 140PSEA041 79 14-PS52 , new unused
Oregon PowerSharp A041 52dl (140PSEA041 7P)_1.JPG Oregon PowerSharp A041 52dl (140PSEA041 7P)_3.JPG
2:28 AM
Oregon PRO-AM , 24" 3/8" .058" 84DL D009 , part number 248SFHD009 , new unused
Oregon ProAM D009 84dl (248SFHD009)_1.JPG Oregon ProAM D009 84dl (248SFHD009)_2.JPG Oregon ProAM D009 84dl (248SFHD009)_4.JPG
2:28 AM
Dolmar PS-9010 PHO , new never fueled , front 14mm bar studs
2:28 AM
Dolmar PS-7900 PHO , with large dual US Style 2 bucking spikes , fully fueled , used and certainly has some oily wood chips stuck on , mild muffler mod with bird cage still in place (if desired I can swap over a stock muffler from my PS-6400)
2:28 AM
Dolmar PS-311TH , fully fueled , with 10" 3/8" Low Profile .050" 40DL B&C , chain is close to being worn out , used and certainly has some oily wood chips on her
2:28 AM
Nice work!
Thanks, froze my fingers off messing with those bars out in the cold.
Those are the bars that are not mounted to saws permanently (spares and secondary setups) , I will supply some additional bar weights just gotta take them off the saws.
Use whatever You feel is appropriate.
If You want the original pictures in full resolution (the forum resizes pictures) I am willing to upload them all to WeTransfer for You to download, it would be a total of 35.2MB.
2:28 AM
Nice work!
If I should do anything different let me know.
If I am going to post weight pictures may as well do it correctly.
00wyk
1:28 AM
Ireland
It's fine. I'll put them up on the web page tomorrow!
Cheers!
We're also getting the cold spell, too. Was snowing the other day and it's still here.
00wyk
1:28 AM
Ireland
Your editing was perfect - made it a cinch to put them up on the web site with very little editing.
I also have an Iggesund forest bar. Mine is a 98DL version(30inch). I now know I haven't weighed it!
But your scale pretty much confirms what I assumed - they aren't very light ;)
That's OK, though, because they are pretty tough.
2:28 AM
I don't mind the weight of my Iggesund Forest bar, at 36" I prefer it to be tough and not flex easily.
I wish I had sourced more of them when I had the opportunity, at least a 30" to fill the gap between my 24" and 36" bars.
I need to get me a new 115DL loop or two, I am on my spare now. Thankfully I don't use the 36" all too often, but it is a fun setup.
2:28 AM
I may soon get You a couple more bar weights! :)
