One ring vs two
bwalker
8:59 AM
Montana
I thought that sort of balance was only relevant in an engine with multiple cylinders?
A single cylinder engine can never be perfectly balanced accross ita wntire rpm range. So typically the balance factor is tuned such that the engine is balanced in the rpm range it mostly runs at. Adding or removing weight changes this rpm.
Deets066
AKA Deetsey
8:59 AM
Would harmonics be a better term for what you are referring to? There again I've only related that to multiple cylinder engines
Deets066
AKA Deetsey
8:59 AM
This true for a rotating mass; when you add the reciprocating mass of a piston however, it is possible to achieve perfect balance at only a certain speed.
How would one know when this "perfect balance" is achieved?
awol
7:59 AM
Cabool, MO.
paragonbuilder
8:59 AM
Norwich, CT
I have. And Mccullochs bp1 also. Amazingly smooth aren't they?
On a saw with no anti vibe it can be easily felt.
It's like an unbalanced rim on your car. It vibrates like hell! But then there is always that one speed, never the one you want, where its smooth as glass.
