One ring vs two
Jughead
5:29 AM
sure a snag wouldn't catch a loose ring easier?there is a slight difference there.
P.M.P.
Stiff Member
5:29 AM
Michigan
I hear you so does the one ring piston faster in the cut than the 2 ring stock form 372 xp?
Nitroman
1:29 AM
Southwest Alaska
Without mentioning any names of who built something .............
1. Is there an advantage of removing the bottom or top ring ?
2. What gains would I expect to see if I removed one of the two rings ?
3. Is there any truth to the "rumor" that removing the lower ring results in a dry bottom end ?
4. What losses should I expect to have with the lower ring removed ?
You question(s) could be answered by looking at a Diesel engines' pistons and rings.
