Broken piston crown (Echo CS-7310p)
bwalker
1:26 AM
Montana
Same customer, different saw (620 instead of 7310). This is the 3rd time this saw has had this exact failure, which I blame on overspeeding. I put a 590 single ring piston in it so hopefully the ring lands are stronger.
Lots of oil, but the piston got toasty at some point.
View attachment 482615View attachment 482616View attachment 482617
Ring gap too tight. Piston appears not to be ran too hot or it would show "death ash" beneath the crown, which it doesnt have.
legdelimber
1:26 AM
N.C.
I've seen some Echo blowers pb-403 pb-413 and pb-620's , that the exhaust port was nearly flat on top. High hour landscaper units. Machine marks worn off of the pistons and the cylinder plating looking thin in places, in the couple that I pulled the cylinder.
At idle, the rings sounded like a spoon player.
I was truly surprised that the pistons tops or rings hadn't been broken on the exhaust port.
Guy said that he had never run anything but Echo Power Blend oil in them.
No idea of the ratio.
Edit: the looks of things would make me think the ratio was no heavier than 40:1 on the oil.
EFSM
12:26 AM
Extreme southern IL
There is no scoring, which should happen during a case of the ring being tight. Also, a tight ring gap would show up before a year of hard use. I actually don’t even bother checking the ring gap on Echo pistons anymore because I haven’t ever found one that needed adjustment.
bwalker
1:26 AM
Montana
Scoring often doesn't accompany this situation.
And it can go along time before manifesting itself. All it takes is a heat excursion, the rings expand, rings gaps close and boom.
bogieboy
1:26 AM
Kingsport, TN
Out of curiousity, whats the piston to cylinder clearance? That slug looks aweful worn, as i dont see any mavhining marks left on it... which can cause piston rock, and added stresses to all the piston surfaces....
EFSM
12:26 AM
Extreme southern IL
I didn’t measure, but it wasn’t too bad. The worst cases I have seen are concrete saws (where the skirt can wear through) and a pair of 562’s that had such worn skirts they no longer ran due to low crankcase compression.
EFSM
12:26 AM
Extreme southern IL
One ring end gap .014, other is .018.
Side clearance (between the ring land and the ring) is .004".
Apparently this saw had quite a few hours put on in 13 months.
bwalker
1:26 AM
Montana
So what the gap spec? Only thing I could find was a max of .024..
