One ring vs two
jmssaws
Banneded
5:16 AM
Did stihl change there rings at some point in the 066/660's? Seems I've noticed two different styles.
jmssaws
Banneded
5:16 AM
Not the thickness just the style,they just look different than they use to. More of a bevel perhaps?
Jughead
6:16 AM
ho lee chit!.......geeks!
wait a minute!wonder how much residual oil the bottom ring land will hold only using one ring.....vs only running one ring in the bottom land.running the ring in the bottom land would create a space for residual oil for top end lube there fore creating less friction But uh... i got a headache.
jacob j.
Only the weird
3:16 AM
Coastal Oregon
Nope,wrong analogy. More wheels,more rolling resistance. And pulls through the curve harder.Trust me.
Why would a manufacturer opt to use two thin (or thinner) rings as opposed to one thick ring?
exSW
'Cause Thomas is a poopyhead
6:16 AM
United States
In automotive applications some rings are " wiper" rings . As far as saws,ask a design engineer.
bwalker
6:16 AM
Montana
I messed with running single ring Wiseco pistons in dirt bikes vs the stock double ring pistons. I didn't notice any differance in performance. They also seemed to lose compression a bit faster.
With that said I have totaly abused single ring Husky's and never had one loose compression.
tree monkey
5:16 AM
wi
aint questioning you, but why?
the open ring grove is a free port from the transfer port to the exhaust port. this happens before the transfer port opens.
postage is gonna eat me alive if'n I gotta send nine more :)
c'mon Dave ya fat *f-word, maybe multi quote now and then, you don't even want a new husky, geeesh
number 11 will be even better:)
wouldn't an empty groove carry a bit more oil and weigh less than filling with something?
maybe my brain istoo tired to get it, I will re-read after a nap
yes, but is it worth the trade off?
The opening of the transfers are not as big when you don't have to raise them a mile.
port area is the same. the piston covers part of the port at bdc
If you start out closer to your desired transfer degree, the final transfer opening won't be as tall. Smaller opening= better transfer velocity
read above, think about it more, your close
jacob j.
Only the weird
3:16 AM
Coastal Oregon
The point I was making is that there are trade-offs with each design. Thicker rings give better sealing at the trade off of higher friction (referring your 'rolling resistance' analogy). Thin rings give less resistance but higher overall RPM with quicker spool-up and poorer sealing. One ring gives less resistance but less overall durability. It all comes down to the performance characteristics that are desired.
Less friction
Less reciprocating mass
Yep. Early saws (long before the establishment of the EPA) had two, three, or four thick rings with heavy cranks and flywheels. Stihl started experimenting in the late 60's with one thin ring and one thick ring, or two thick rings spaced a long way apart. IEL had a thick ring just below the crown of the piston and a thick ring on the bottom of the skirt (supposedly for stability). Husqvarna experimented with three and even four .024" thin rings (the 394 prototypes came with triple thin ring pistons). McCulloch and Homelite developed their own 'Dykes' ring designs with one L-shaped ring right on the edge of the crown.
As saws evolved, crankshafts, flywheels, connecting rods, and pistons got lighter. Chain and bars were reduced in mass. Clutches and drums got thinner and lighter. Materials and manufacturing methods have improved. Now you have equivalent displacement saws that weigh a fraction of what the same displacement saw did 30-40 years ago. So now, different performance characteristics are desirable.
Deets066
AKA Deetsey
6:16 AM
If the area is the same at BDC you would still pick up velocity if the uppers are smaller. Not because of area of port, but it would be less case volume if they were ground on less?
Deets066
AKA Deetsey
6:16 AM
So a guy could possibly epoxy up the bottoms of the upper trans to just below the piston crown at BDC and maybe pick up a little?
Deets066
AKA Deetsey
6:16 AM
It might be more work than it's worth after thinkin about it.... I'd have to look at a jug to see if it would even be feasible.
