One case tool to rule them all!
RI Chevy
9:58 PM
earth
WTF
Derf
9:58 PM
Long Island NY
It has arrived and left the Hartford CT Distribution Center! I hope it's getting closer to you Matt!
Mattyo
Youtube speciawist
9:58 PM
Farmington, CT
Gonna try to pick it up at my local post office this am. If it gets put on the truck. ...then I won't have it till tonight. If I get it this am....maybe I can get a few packages together and start playing catchup
Mattyo
Youtube speciawist
9:58 PM
Farmington, CT
Packing stuff up now...
Hold off on that shipment Tom...
Yours is coming :)
I got 11 kits to send out this am....gonna do my best
RI Chevy
9:58 PM
earth
You better put homing devices in there Matt. Lol
Or try UPS.
You know what they say about the definition of insanity. [emoji2]
Mattyo
Youtube speciawist
9:58 PM
Farmington, CT
As bad luck would have it The sleeves are still too tight so I spent this morning using my new 16mm drill bit to remount the sleeves even further and it was very very difficult But I was able to get three kits shipped this morning and I will have the rest of them shift tomorrow morning
twinstaged
9:58 PM
Ohio
What does the outside of the threaded rod mic out to? Crazy it won't slip through a 5/8 drilled hole in aluminum... I'm assuming the bores aren't straight and it hangs up mid way? How long are the sleeves?
twinstaged
9:58 PM
Ohio
This is exactly what you need for enlarging the sleeves. This is a 12 inch one but you can get very long ones as well. These won't follow an off center hole as readily as a twist drill will too. Not as good as a boring bar, but very fast and makes a nice round hole. Can even get them with Morse taper ends if you don't have a big enough drill chuck.
https://www.ebay.com/i/122580604295
Mattyo
Youtube speciawist
9:58 PM
Farmington, CT
Hopefully this is all moot on the next batch....if I can find aluminum tube with 5/8" id with some good wall width...it'll be fine. ....but that is a cool drill :)
RI Chevy
9:58 PM
earth
Check with Alcoa Aluminum Matt.
Mattyo
Youtube speciawist
9:58 PM
Farmington, CT
I've been ordering from speedy metals....they seem to do a good job. Does Alcoa sell to the public? The issue is that ive got small orders....
RI Chevy
9:58 PM
earth
Not sure Matt. I used to buy from a dealer a while back. I bet if you contact a local Alcoa dealer, open an account, they will sell to you if they have what your looking for.
twinstaged
9:58 PM
Ohio
Speedy isn't bad, but they are charging a premium. No industrial areas around you? I feel a bit spoiled sometimes that I can drive a mile and have my pick of what I need for bare supplies and tooling.
twinstaged
9:58 PM
Ohio
Well after a couple minutes of searching unless your ok with .120 wall thickness I don't think it's economical to buy the .250 wall stuff unless you can get it direct from the supplier. Your design is hitting a wall for off the shelf availability, amount of material used, number of steps and times it's handled vs what you can sell for. Just my outside looking in thought.
