Oil questions...
pbillyi69
6:39 AM
USA
I believe its the opposite. Filter gets clogged, less air gets in. It leans the engine out to maintain rpm.
thats right. what i meant that it changes as it needs to so it stays running at max power without having to manually adjust a screw
dangerousatom
9:39 AM
Quakertown, PA, United States
Air Temp and Altitude/Ambient air pressure and how smooth its running ( a knock sensor type detection ) is about all the new compy-controlled saws read. They control RPM with basically only those 3 things. That's why the don't run great at partial throttle.
From what I can tell the saws dont know what Octane your running or what mix ratio. I believe there is a "sweet spot" window that the programing is shooting for, thats why they are constantly adjusting while cutting or idling. With an EGT and O2 sensor you could squeeze more out, but that leads to a bigger control chip, more programing and the need for more sensors. Those additions on a small engine let alone a 2-stroke have way more failure potential and just issues in general. That along with a likely battery or winding like a heated saw has to run all the unneeded sensors.
IMO the new Auto-tuned/E-tronic saws are just a way to get big Gov/EPA to pat the company on the head and say good job we wont bother you for a could of years now. I dont even believe they are more efficient or cleaner in the long run of use. If they are less a saw in terms of power and reliability then your going to use more fuel to get the job done or buy more parts because of failure witch is basically fuel in one way or another.
-Getting the job done in the least time and fuel efficient way along with the use of the simplest, least "break down" equipment is always the most economical on all levels.
bwalker
9:39 AM
Montana
There is zero doubt they are cleaner and more efficient.
9:39 AM
I’ll share it again for the guys that haven’t seen it. This is dominator at 32:1 in my ported 2153 after about 25 gallons of fuel. It goes to every gtg with me and cuts maybe half of my firewood each year
Almost 0 carbon. No buildup anywhere
SawAddictedFarmer
8:39 AM
redneckhillbilly
7:39 AM
NW MT
I just wanted to be absolutely sure before running it in a really expensive saw!
You all are awesome!
did you make the switch to 32:1? I burned a gallon through my huskys at 32:1 and they did just fine, I'm going to be keeping it there from now on.
SawAddictedFarmer
8:39 AM
I haven't even had time to cut. We've been working on our biggest tractor that quit moving. Hopefully once it freezes and life slows down though. Any noticeable power difference?
hacskaroly
2100 Fanclub Member
6:39 AM
Northern Idaho, Ehh
How often do you have to clean your spark plugs (from normal use) or do they also stay just as clean?
hacskaroly
2100 Fanclub Member
6:39 AM
Northern Idaho, Ehh
Why 32:1 and not the manufacturers recommendation of 50:1 ?
Welcome to the forum. The use of mix oil at the manufacture's recommendation and everything in between is used by people here, there are lots of opinions and lots of people who have been running their numbers for years. From what I understand, the quality of oil is the biggest key. I switched from 50:1 to 40:1 as most of my saws I have are 1990's and earlier. Even the couple of newer ones I also run at 40:1.
You can use the search function and find the many threads that discuss the different ratios and people's opinions about it.
Here is one thread:
9:39 AM
Maybe this guy knows what he's talking about; he keeps saying he's got 40 years of experience... But with his droning voice and hand-held camera shaking around I felt like I was on a deep-sea fishing boat in a storm with Eeyore. I could not finish watching.
He definitely knows what he’s doing. He is tree monkey on here. Been porting saws for longer than anyone I know
pbillyi69
6:39 AM
USA
if you read the paperwork that comes with most saws it says if using a different oil than they recomend to mix it at 32:1 because they cant verify that mixing other oils at 50:1 will be enough protection. 50:1 is for the epa mandates. 32:1 is just better.
