R2D
- 7:45 PM
- Dec 24, 2015
- Northeast il
Putting back together another nice 2100
Very nice what are your intentions with this saw?Putting back together another nice 2100![]()
Not sure yet. But if it sits around here long enough, it will get sent down the road.Very nice what are your intentions with this saw?
Very nice! Ha ha, he was thinking same thing I was. On plans for itNot sure yet. But if it sits around here long enough, it will get sent down the road.
I havent worked on these much but just learned to make sure the intake spacer is on the cylinder before the cylinder goes on the case.Putting back together another nice 2100![]()
Yep and they crack if you crank on the screws to hard. Don't ask me how I know : (I havent worked on these much but just learned to make sure the intake spacer is on the cylinder before the cylinder goes on the case.
Wish I had read that somewhere first. Maybe someone will stumble into this before they do the same thing.![]()
No gasket thereis there supposed to be a gasket between the carb and the filter elbow? Mine didn't have one when I took it apart... seemed like it had a good flat mating surface that nothing would get in there...
Yes definitely a learning curve. But once the 2100 Is learned, it's one of the most simpl, and easy to work on designs I've seen.I havent worked on these much but just learned to make sure the intake spacer is on the cylinder before the cylinder goes on the case.
Good morning buddyHi norm : )
Nice! Hang on too that one. Randy is too shelf.I have a 2100cd mastermind ported mine it runs very well
Nice! I have the same v-stack!Just waiting on a couple bits to put this one in wood.View attachment 21406
Heres mine with a 36". It still needs a chain tho. I just worked a deal with a friend for an old 2100 and 3 boxes of parts for $250. Still gotta pick it up. The saw is kinda rough but has pretty new top-end. Tons of compression but no spark.
