T.Roller
- 10:35 PM
- May 11, 2016
- Southeast, TN
That escalated quicklyYou cut like a pussy anyway..who cares.
Wow that's my fault man, I totally mis-read your post...I thought you said it "isn't" worth it to change the parts LOL....I cant say i paid close enough attention bruh..
But..i put the 461R pump parts in one of my 361s thats ported and i just ran it yesterday with 28" on a good sized removal and it wet the bar good...and the saw has the balls to pull it with full skip.
So after you changed the pump/piston you could tell thebsaws oiled a lot better???
And was putting the HO oil pump parts in easy...i remember seeing a thread in it a long time ago, seemed quick and simple...
Well hello sir, I respect your honesty, at times I also have the short attention span, so I understand....Khntr85: I skipped most of this thread because I have a very limited attention span. Here's my opinions, based on my MS461 that I ran stock for a while and then had ported.
1) It's very easy and inexpensive to upgrade the oiler to h.o. capacity. I'm sure I've already sent you the links to parts and procedures. I would do this to any 461, no matter what.
2) A stock MS461 will run 32" full skip chain n hardwood just fine. Ported, you can go to full comp.
3) Gauge of chain/bar, i.e. 0.050 vs 0.063 is irrelevant. Either one works fine. 0.050 chain is easier to find then 0.063. Personally, I'm switching all of my 3/8th chain to 0.063 just because I like the Tsumura L&T and it used to only come in 0.063. I see that @Ford 150 has been importing 0.050 Sithl bars recently, so if I had it to do over again, I'd stay with all 0.050.
Hell ya man....if you don't mind, what does each of the the parts cost at the dealer...and I mean dealer price, I know some dealers inflate everydamn part they can LOL!!!Sawmikaze likes moddin oil pumps on 361s and 362s so much now he keeps spare bolts and pistons on deck.
Love my 046s. ,my favorites. Pre epa restrictions and screw caps!!I haven't had a chance to run my 461s yet but my 046s will oil and pull a 32 good I run full comp chain
My ported 460 with H.O. oiler pulls a 28" well and I think it would do in a pinch with a 32". I usually grab a bigger saw for that length though.
No replacement for displacement, especially if you add porting to that.![]()
Original poster clearly stated hardwood... get an education...
Sent from my SM-T377P using Tapatalk
Not according to the internets ,20 inch maxThere is enough displacement for 32".
Not according to the internets ,20 inch max![]()
PM sent!
