MS461 28"-32" bar and chain options???
Khntr85
1:02 AM
Indiana
The Squeaky Wheel
Lol...
How did your 461 run that bar....I seen it was "monkied" with lol, I bet she screams...
Do you run full comp or skip on the 32"...
bikemike
12:02 AM
Cottage grove mn
Hey thanks for reply...
Does the 32" bar get enough oil???
What gauge do you run .50 or .63????
All the saws we have at work are .63. I'm shure it won't have a issue with oil. Especially when you work the saw for a bit and the oil gets hot from engine and exhaust
bikemike
12:02 AM
Cottage grove mn
I'm going to sell my Oregon RW 32" 0.063": I haven't posted it yet.
It's nice.
Did you cut through the hinge on the right side?
hseII
Heef
1:02 AM
West Georgia
It does look a bit sketchy in the picture,but I would have busted that saw log had I not.
bikemike
12:02 AM
Cottage grove mn
Almost, but not completely.
That tree was in line with the 2 in front of it, & I thinned it out to lay just to left, beside the other one in the pic.
I was wondering about that. The pic was hard to tell to the structure off to the left as where the tips would land. But looks like some fun drops.
1:02 AM
I don't know why but it doesn't overheat as bad or plug up with dust. Milling shows it over 24". I have a 32" 050" but rarely use it. I'll use a longer lightweight bar in 63" even with stock oiler on the 46s
Khntr85
1:02 AM
Indiana
Understood....
I ordered a 32" .50 with a loop of Oregon skip....I am anxious to see how it runs!!!!
sawmikaze
1:02 AM
steeltown
My 461s oil a 32 with 50 gauge just tits.
I think timber fallers like the 63 not so much for the oil capacity but the stability of the chain on the rails..atleast thats what my friends say.
For occasional firewood cutting its a non issue...go with whats available to you locally incase you need to buy a chain in a pinch.
TreeLife
I'm Dominick
1:02 AM
I like skip tooth better cause it's less teeth to sharpen! lol!
I also like skip on long bars for that reason, just makes my life easier when I'm using them all day. I like the 28" RW Oregon bars, but that's because I have a saw in my hands 6 hours a day :-)
Khntr85
1:02 AM
Indiana
Good to hear it oils the 32" sufficiently....around me .50 gauge is most prevalent....do you run full comp or skip on the 32"....
Ya for just firewood a guy can make anything work...to firewood guys around here a ms290 is a big saw lol!!!
I was just wanting to make sure I have a rig I can use for hours on end without fail....
Khntr85
1:02 AM
Indiana
I also like skip on long bars for that reason, just makes my life easier when I'm using them all day. I like the 28" RW Oregon bars, but that's because I have a saw in my hands 6 hours a day :)
Are you running a 461 or that 7910???
sawmikaze
1:02 AM
steeltown
I run full skip now because i can file it quicker and i dont use a 32"bar enough for the durability to even matter...and it clears chips better.
