- 4:24 PM
- Jan 14, 2016
- North western Ohio
Yep and I robbed two 10-10 righties of their cranks failing to realize the flywheel on my 6-10 was faulty . I don't know if it might be something they could be welded ,turned and ground .Possible I suppose but I doubt I'll ever do it .The super 6-10 used a later thin steel ring non- full skirt piston as well as the early rhs 7-10 with iron bore. I believe the full skirt was used on the 54cc engines for ballance. both engines used the same crankshaft.
