- 1:03 PM
- Dec 24, 2015
- Coastal Oregon
Old vs. New - iron-liner 125 vs. 125c.
Very nice!!!Old vs. New - iron-liner 125 vs. 125c.
Very nice!!!
Not sure which one is the C but the second saw is getting it done.
Very noticeable difference. What carbs are on both and are both
recently rebuilt
I could be wrong on this but i bet if the iron liner saw had a few tanks run through it to break it in it would
most likely perform much better. The chrome bore saws tend to break in much sooner with little run time.
@jacob j.
A few pages back, you referenced running a Tillotson HS- 296 from an 390xp as a potential carb on one of these saws. Did you ever make that happen?
I’m looking for an H and L adjustable carb for a Super Pro 105. SDC-20’s are difficult to find and I am leery of fitting a smaller SDC from a 10-series, although that is my current best option
@jacob j.
Look for an SDC-37 or 38. Same venturi as the SDC-20
A couple changes would need to be made if wanting to use a 37 or 38
1. - Convert to external impulse
2.- A small amount of material may need to be ground away from the manual oiler button boss to clear the adjustment screws (not on all 105/125s, it depends on which tank they have)
3. - Throttle shaft may need to be changed to be compatible with the 105/125 throttle rod, or a new throttle rod may need to be made.
I think all the SDC's that MAC used were a fixed main jet.
Here is a Walbro SDC-37a from a 10-10A mocked up in a Super Pro 105. The manual oiler boss will require clearancing. The throttle rod is easily fit with a drilled hole. The choke should be very straightforward. The impulse nipple would be simple.
I’m not familiar with how grinding the oiler boss in the tank will impact the manual oiler.
The 372 carb I have to reference is a Walbro HD which is absolutely not a fit. The carb must have mounting holes angled across the Venturi to fit well in the carb box.
SDC-65 from a Pro Mac 10-10 with angled needles requires significant clearancing compared to the SDC -37.
