Mastermind Meets The Echo 800P
bryanr2
9:56 AM
USA
Hey Man, I have one. It's a HDA 63-1 16.66 venturi. I put a ported quad top end on an 8000, the HDA 153 on the saw was junk and I scored the 63-1 on ebay a couple of years ago. I suppose I could swap it for the 800P carb to see what you can get out of her. Don't use the 8000 accept for the occasional stump. Pulls .404 full comp on a 24" bar pretty well. Let me know if want it and I can pull it for you. I bought a 2188 you build and I'm impressed every time I run it ! Lived in Tennessee 24 years, miss it every day. Larry
Who did you get your 2188 from?
8:56 AM
I'm sure the owner would love to have that carb Larry. I'll send you a message, thanks a lot.
bryanr2
9:56 AM
USA
Yep, it's that one. Bought her from Mr. Graham. I have run several gallons through her so far, she's just getting broken in. Still looks like new, I take good care of my equipment.
That was a strong saw. Clint got it from me. I bought it from Like2Surf in June 2013. Randy brokered the deal for me, as it was the week my FIL passed away from stage 4 glioblastoma brain cancer.
Larry Joe
6:56 AM
Northern California
I had tracked it's history on the other site, when you sold it to Clint. I would imagine it's an even stronger saw now. Run Belray H1-R @ 32:1 tuned at 13,100. Dropped many tons of Eucalyptus with her this week. Pulls 34" full comp right nice. Take care, Larry
8:56 AM
Larry, thanks man. I'm sending the carb onto Rob, and I'll get him to send the OE carb on to you. Very nice of you sir.
I just left Rob a message to call me........
Idahonative
O.P.E.f.o.r.u.m. Mutt
7:56 AM
Idaho
Wow. I'm humbled by the quality of people on this site...unbelievable. Thank you Randy and Larry!
MemphisMechanic
Unreliable Chainsaw Enthusiast
8:56 AM
Memphis, TN
Zombie Thread alert!
(And apologies)
I recently picked up an 800P with 36” bar for an <exceptionally> fair price. However it is an utterly gutless pig, and I’d currently rather mount a 3ft bar on my ported 044 than this brick.
I intend to give it a fairly unremarkable port job (80/100/120ish) and keep it in the truck on removal jobs as a backup saw for big wood, but the carb has me concerned. I’m no carb guru, and if it gave @Mastermind the runaround, I’d prefer to avoid even trying to make the 800P carb work.
Does anyone have a source for the larger 16.6 HDA carb off of the CS8000 series of saws? Google is being typically unhelpful and recommending me scores of parts for a Timberwolf, etc
Red97
9:56 AM
MI
(And apologies)
The 620p carb is the same large ventiri. Would have to swap the shafts/linkage around to use it.
srcarr52
9:56 AM
Iowa City
If it's the same carb body but only the venturi size is different... what's stopping you from tickling the venturi?
Red97
9:56 AM
MI
Should be doable.
MemphisMechanic
8:56 AM
Memphis, TN
Absolutely.
In your estimation, should I expect to need to drill the main jet or do other similar modifications to the 620P carb, or do you think it’ll be up to fueling a mild port job?
Just going to delete the base gasket - presuming acceptable squish - and grind for 80/100/120 or thereabouts. I’m not looking to build a jaw-dropping saw. I just want it warm enough that you don’t fall asleep out of boredom while stumping a large tree with it.
8:56 AM
Red97 would be the guy to ask. I do very very few Echos.
