Mastermind Meets The Echo 800P
6:08 AM
Throttle linkage kept coming out of the trigger. Worn parts.......
I kept tweaking the throttle rod till it was OK.
Now. The Echo will go over 14,000, but not with a strong 4 stroke. At 13,800 it's 4 stroking real good. The chain is going on the grinder now........BRB.
Idahonative
O.P.E.f.o.r.u.m. Mutt
5:08 AM
Idaho
The 800's gonna seem like a real monster after messing with that 200t...LOL:).
David Young
Safety First !!!!!!
7:08 AM
vt
sometimes you can do small tweak with the L needle.
I fought with the master control lever on a 200 worked good with the cover off but wouldn't with it on. turns out the kill switch spring was not pushed down all the way.
DSS
widebody
8:08 AM
canuckistan
Nice! What did you do to the carb?
Idahonative
5:08 AM
Idaho
Not happy with the way it tunes. It will be fat as hell........then go lean for no good reason. Looks like it's time to dig into the carby.
Just to be clear...are you having problems with the 800 carb or the 200 carb? I first thought it was the 800 but now I'm thinking you might have been talking about the 200t (I can be slow).
Hedgerow
6:08 AM
The 800 carb is going lean.
I could hear it after the cut was done.
He's fixing it.
With a meat tenderizer.
