Machining base without a lathe*
11:07 PM
I just did the squish on an 026 jug. Same area read .022 with .032 solder and .018 with .023 solder.
That was measured with a micrometer and not a caliper.
Just goes to show that you need the closest solder possible to your intended goal.
After coming into contact with the piston how many times? I always roll the flywheel back and forth until I can barely feel it. Takes maybe 10 or 12 times back and forth with .031 solder
11:07 PM
Using .032 solder if the flywheel tries to take your finger off after the first squish. You still got .006-8 to go.
Yea I always try to give it a flip the first time and get my sausage fingers outta da way. That hurts when it rolls over TDC and jams your finger into the case housing
czar800
11:07 PM
Ellwood City
I'm just glad I'm not the only one who has done it.
Of course I've done it multiple times. :hollering:
Red97
11:07 PM
MI
Hence the reason I use the pre squished pieces now. Don't even bother bolting it down till I know I'm in the ballpark.
Plus I busted a cast key out of a flywheel by not having it tight while checking squish. That hurt in more ways than one..
11:07 PM
You're likely correct. Probably the same amount on both sizes.
czar800
11:07 PM
Ellwood City
I'll be copying your method, Thanks for the tip.
Termitebuffet
Home of the corn can muffler .....
11:07 PM
Midgetville Norf Kacolacky
Like this......[emoji27]
Zoo City Sawz
