- 7:16 PM
- Jan 26, 2016
- South west UK
Ok fair point I was thinking about taking the 6100 to maximum cutting length and see how much this saw has got in there
Go full comp with confidence!I want to get a long bar for my Makita 7910 to help out a buddy cut up a large silver maple and willow. I usually run a 24" bar but from his description I may need something longer. I have done the oiler mod and it really oils now. I have a line on a 32" GB in 3/8" .050 105 dl.
Please excuse my ignorance, but I am wondering what chain to get for this bar? It's not green wood, it's been down since fall. Never bought a chain this long. Should I get a Skip tooth. Is that in order? Or What chain?
The 7910 is muffler modded and will probably have the 272 coil installed by then. I don't plan on using this set up often, just trying to help a buddy out this spring.
Full skip can be a bit rough in small diameter wood, but cuts great as long as you have 3+ cutters in the wood at a time.
Since I first posted this I've gotten rid of both the 24" and the 32" and went with a nice and light Sugi 28". I wish I would have done that from the beginning...I would have saved a lot of money. I shortened the 105dl skip to 93dl and will make a full 93dl for it too. I'll buy a few more of each.
After it's ported I think that this bar and chain(s) combo will be perfect in any wood.
Is it just me that finds it interesting how our bar length choices seem to float around over time? I started with a 20" Tsumura, then 24" then 32" and find the 32" seems to stay on the saw nowadays and I use a smaller saw with smaller bar instead if I want less reach rather than change bars.
If I could find a 18" picco bar for the small saw, I'd probably give the 20" Tsumura bar away.
Essentially, each saw seems to end up wearing the maximum sized bar it can handle.
Let us know how the different chains compare in your cutting?I shortened the 105dl skip to 93dl and will make a full 93dl for it too. I'll buy a few more of each.
I think each saw has a sweet spot in the combination of: powerhead, sprocket, bar, and chain. Might not be the longest bar. Might have to do with balance vs capacity. But the right combo will also vary in the type of cutting one does, the type of wood, etc. One guy's 'limbing saw' is another guy's 'all around saw'.Essentially, each saw seems to end up wearing the maximum sized bar it can handle.
Very solid advice there. The more you play with stuff, the more you understand what makes a good combo.Very good post, and very valid points made.
My preferences in 3/8 are;
20" for 60cc's
24" for 70cc's
28" for 80cc's
32"+ for 90cc's
I have been running a 32" RW Oregon on my 395, and though I know the saw will handle much more, (as with all my saw set ups) I prefer to operate under the "more power is better" theory.
The upside to CAD is that [we] can try every bar, and chain set up without having to remove a single bar nut......LOL!
I have no experience with square filed, but the biggest problem I have noodling is keeping the noodles clearing the clutch cover. West coast style or not.My first real experience with chip clearance was a couple weeks ago. My 066 with 36" square filed lpx and my 7900 with 28" square both were very slow noodling poplar. Crosscutting, I can bury the bars and load the motor. But I really had to dog in and pull up on the rear handle to keep noodling. I need to try a couple loops of skip
The best I've used for noodling is a 7900. The taper inside allows them to flow through nicely. If a guy noodles alot, I'd pick up an AM clutch cover and cut off the lower left 1/3. Then they just fall outI have no experience with square filed, but the biggest problem I have noodling is keeping the noodles clearing the clutch cover. West coast style or not.
Other than power, the 6400 will noodle as good as any. Very few sharp corners inside the coverI've got a 6400, but haven't tried it noodling yet. Always ran Stihl saws. Haha!
Crazy stuff some of the dry gum. I've only six, 32" chains, most of which are skip but when bucking a dry gum for firewood recently, it was about one chain per 1.5m of log if that. The sort of ugly bastid log where the grain does a full 360 degrees around the log in about 1.5m too. But it was big and I wanted to see if it was just the first 4" of sap wood that was spiraling. Tried splitting it today but gave up after about an hour. I should have not even considered it as firewood after I was producing noodles just cross cutting it. Am very glad I saved out a 5m log from it though because the grain is all over the place and has that fiddleback type of figure going on. Looking forward to slabbing it but not looking forward to sharpening multiple 72" loops, even the mega-skip RX ripping chain that has relatively bugger all cutters.Went through 8 freshly ground chains in not much over an hours work!![]()
