Little China Girl
3:52 AM
Also, don't know if Randy realized, but my belt sander is just a little hand held job from HF!
Wagnerwerks
3:52 AM
Pa
Lol. Looks like you guys covered sharpening a bit!
I will add the reverse in a drill grinding method does work well to return a broken bit to uniform sides.... Then you need to sharpen it.
I'm to busy to use a jig.... The lift method is what I was taught, but I usually grind the cut edge and then do another bevel behind it. I find it easier and they cut well. Practice makes perfect. I've broken hundreds of drill bits.
Member
2:52 AM
POS drill press, made a poor end mill. Thought this would be the neatest way to go. Was going good until the head spun and walked over.
So I went into full Mongo mode, ground it out instead. Took a bit of time, but end result was better.
